Picture Attachment
Hi Mike,
You can't do it mate.
You have to upload the picture into the gallery, then link to the URL (make sure you get the URL from the Pictures Properties and not the gallery page).
Ian.
strange.. the permissions were set correctly.
i know a non gold member cannot post but i can see goldies can...
can a few others verify that their is no browse option when posting?
you can do it..... like this though:
when you reply to a post, there is a "file attachments" section atb the bottom below the smilies. Press the browse button and your image will be linked like this....:
This is the error message I get everytime I try to add a picture from the gallery :sad:
I click on the IMG button, enter on the full URL including the extension and then end with IMG.
Not sure what I'm doing wrong. It's never worked for me :unsure:
I've had this problem recently - inline images using the IMG function seem erratic. It's fine to add a 100k attachement though.
Used to work.... :mat:
Ifraz
that image is not in the gallery buddy.
nothing wrong with the tags you used in the post - its just the file is not on the server.
the forum software puts user posted image into the post when this happens.
Ifraz
Matt,
If I insert a hyperlink to an image, it works fine Image
But when I try to display the same image within the text I get the error. aai.jpg
:unsure:
Ifraz
Matt,
:unsure:
Ifraz,
Are you linking to the image or the page that the image is on??
Try right-clicking on the image..
Select properties..
Copy the location URL..
Paste this as your image location..
Ian.
Hi Ifraz.
This is with your link
I have added /albums/ in between /gallery/ and /album08/
If you use the method I suggested above, it should work..
Ian.
spot on Ian
have to be aware of the size constraint as well though.
the second image Ifraz tried had the correct path - but was failing because the image was larger than 1000k.
for large images - your instructions are still valid - but they need to be applied to the smaller thumbnail image - or the same problem will occur.
