Shocks/suspension Question
IZZZY
Guys,
Im hoping you guys can help.
recently i noticed each time i go over a speed bumb, i can hear a squeeking sound coming from the front wheels, just as they go over.. im guessing this has something to do with the suspension..
what is required to get rid of this sound? greasing?
or do i need to replace any parts? maybe the rollbar linkages? ARB links?
anyone care to advise me please
thanks in advance
try spraying silicon spray on the anti roll bar bushes mine squeeked for ages and while checking for the noise i traced it to the anti roll bar bushes sprayed with silicon spray noise gone and has been for over a year.9 times out of 10 ball joints knock not squeek.
thanks Ormi mate - valued advice.
will get some spray.. can you roughly advise where abouts im looking to spray....?is it fairly easy to access?
they should be black rubber around the the anti roll bar
should look like something like this http://cgi.ebay.co.uk/VAUXHALL-OMEGA-94-FR...=item3efaa9c35c
Thanks Asi.
tbh i prob will not be able to locate it.. im seeing the mechanic tomorrow so will just get this done from him..
cheers for your help mate.
ps. hope the snow is not too bad up your way :-)
if you put your steering on full lock left,go to the drivers side and look through the rear of the front arch you will see two bars one is thicher than the other........the thicker one is the roll bar follow it towards the center of the car and you will see the bush....i will try and take a pic when i get home.
