Where Can I Get T3 Led Dash Bulbs From
lexdavis
t3 ?you mean the center light unit in the roof or the small ones.... called the grain of wheat bulbs.
if so i have just ordered 50 for 5 pounds from eBay
and the center light ones can also be got from eBay
but pm me if you need some blue grain of wheat ones as i will have a few left over
http://cgi.ebay.co.uk/50-x-3mm-Blue-12V-80...=item5d270c5aa7
if so i have just ordered 50 for 5 pounds from ebay
and the center light ones can also be got from ebay
Its the bulbs for the A/C that im after so they can match the single din head unit and the dash bulbs
or if there is a complete kit out there then would be interested
you can have some of my bulbs when they get here. i got some inverted bulbs and did the ac in half an hour with a soldering iron. but these bulbs are not the bright blue that i needed for then.
i got these
http://cgi.ebay.co.uk/10-x-Car-Blue-LED-Da...=item518e8e3dc4
and then took out the blue plastic thing and had the bulb and resistors and just removed the bulb from the ac unit and soldered them in..... looks way better ( bright)
also did the clock and the heated seats the same way. got the bulbs to do the electric window switches and the rear heated seats switches. but if you want some i can send you a few when i done.. not sure how they are going to look. thought i would give them a go.... beats soldering everything
