Our car went in this morning to have a creaking drivers seat and excessive wind noise from drivers door fixed. Both problems were rectified however i have now noticed that if i leave the car with the key when its running it no longer beeps with the warning message KEY NOT DETECTED. Is it possible that this has been disabled? if so can i re enable it or is a dealer fix?
Yes definitely no other key in the car. Should the beep sound when the door is still open and you have left the car?
The external alarm beeps 3 times if i've left the car and shut the door but nothing happens if i just leave the car without shutting the door i.e no audio or visual warning. Is this normal?
