Headrest With Monitors Built-in
jeffrosie
been thinking about doing this myself. you'd have to create a small groove down the side of the plastic things the posts go into.
then just run a coat hanger down the seat, tape the wire to it, and pull it back
Is the OP talking about fitting screens into the original headrests or swapping the originals for the ones you can get off the net that are replacement headrests with screens already fitted?
If the latter then you probably don't even need to put the wire through the post, as it's probably already there?
Not sure if anyone's done it on an IS200, but there was definitely a member who used the preinstalled type replacement headrests on an IS250 and the result looked pretty good.
