Hi, I have as per title have flooded it. I want to know where is the fuse is for the fuel pump. Have looked in both boxes but cannot see one unless it is under a different name. I have seen advice on other sites to stop the fuel and wide open throttle it to start. Have tried all other measures including flat out throttle before ignition turn on.
Thanks in advance
Thanks in advance
All sorted without a reply. Maybe cos it's a Bank Holiday !
What did you do?
If the car floods, normally just keeping the throttle peddle to the floor while continuously cranking will sort it. No need to pull fuses to the fuel pump.
