License Plate Lights?
remove the trim off the boot and youll see 3 or 4 10mm nuts in a row remove these then close the boot and pull the trim above the number plate off dont worrie almost their....
push the clear plastic cover to the left or right i cant remember which way the plastic cover will pull out now and give you access to the bulb.
haha, spot on mate, thanks for that.
