Air Con Filter
Open glove box and you will see two arms either side .push one side in and pull forward past lip then the same for other side and glovebox will swing down and you will aircon unit then pull tray out to expose filter hope that helps
hi guys hope you are all well,i,m new to the club , i,m trying to locate the air con filter where would this be i need to change this ???????
Check with your dealer - most IS200's didn't have one and there is some variation with year and model. The service history doesn't help; dealers are not above charging to change one when it isn't there!
Really? You surprise me.. :whistling:
