does any one know if theres another toyota exhaust box that fits the mk 1 300 sport
i live in portugal and wont be back in uk until september and my rear right hand box has come away from the tube
i am pretty sure it isnt really possible to repair until i get back to uk and as the old lexus models where never imported in to the country i am pretty sure it will be majorly expensive to get one in
alternatively is there a way of buying a rear box in uk and getting it shipped directly.................it looks pretty simple to fix
maybe its psossible to get a cheap (non lexus) back box from a supplier here
Yup, you can get the rear boxes for £25 (GBP) on ebay. Just ask the seller regarding shipping.
is that origional rear box
i tried a search on e bay and couldnt find anything................what should search be
i can get shipped to UK address and get friend to bring it over
just found this, it looks right
http://cgi.ebay.co.uk/LEXUS-GS300-3-0-S-SE...id=p3286.c0.m14
Yup, that's the one.
thanks
i bought the pair...so will change both.....atleast will keep them even and the other is probably due to fail soon
it looks quite a straight forward fit
do you know if the tailpipes from the origional boxes will fit easily
there is one for a mk 2 advertised on e bay, but its only one
what other non standard tail pipe cover would fit
thanks
The original trims should fit but it all depends how easily they come off. If they are stuck solid, any damage or mishaping of the trim will make it more difficult to re-fit. Any aftermarket trims will fit if they are the correct diameter. They just have a habit of rusting more and looking naff after a while. You generally get what you pay for on that score, mega cheap and they will more than likely look cr*p after a fairly short time.
Fitting the back box is easy enough, although you will probably need new bolts, and maybe a gasket (or some exhaust sealing paste as an alternative).
thanks
luckily i got the 2 rear boxes as, on inspection , the other was more corroded than it looked
i managed to sheer 2 bolts taking them off but had some on hand so that was ok
the pipe knocked off ok on one and think the other will come off ok too, so a little polish up first and .....nicely all sorted
thanks for the info
