Shuttering Engine
gcarson
:question: With a 1995 ES300 the engine runs rough, shutters, and makes a rumbling noise about once a or twice a tank of gas. The problem goes away after turning the engine off for about 10-15 minutes. Oddly, the problem seems to occur soon after filling with gas or when nearly empty! The problem can occur at highway speeds or at slow, city speeds. (Two Lexus dealers have not found yet found the solution.) The ERG has been suggested as the problem but this has not been replaced yet. Any other ideas or suggestions?
one thought although not related to the gas it the intake
maf that does give it a bogginh problem
my 94 which shares the same engine had that problem a while ago
i had to clean the sensor out
also the egr shouldn't cause too much of a bogging problem
as i also have a problem with my egr
