It's in a horrible place not easy to get to plus b careful as it's plastic casing  can crack where pipes fit ,on mine it cracked and casing not cheap but luckily mine was fixed .
hi i had my diesel filter changed made a big difference with acceleration no flat spots smooth ,but very testing to get to and changed ,bolts and also getting out to change filter but well worth it in the long run,
  • 1 year later...
12 hours ago, Euromillions said:
Where online would you pick up a replacement filter?
lots of fakes out there, so avoid unkown retailers...
IMO, best value to get as part of a service kit set from a trusted retailer.... I tend to find lexus parts direct often do a good deal, but be careful as they once supplied me the wrong oil for the IS200d   (it needs a c2 type).
An alternative is "parts in motion" ... had some good prices from them also... if not genuine, I tend to use blueprint.
