hi all,
regarding my mk1 gs300 sport. i have just noticed my warning fault light come on. i have checked all my lights and they are working. has anyone used those fault readers you get off eBay, or maybe what i should check next? going to main dealer i want to be my last resort
thanks
finest1
hi all,
regarding my mk1 gs300 sport. i have just noticed my warning fault light come on. i have checked all my lights and they are working. has anyone used those fault readers you get off ebay, or maybe what i should check next? going to main dealer i want to be my last resort
thanks
finest1
Which warning light has come on? Did anything untoward happen prior to the light coming on?
Like Dave, which light came on?
Regarding the fault code readers on ebay: They are no good for the mk1 GS, it isn't ODBCII. Fault codes can be read by shorting a couple of pins in diagnostic socket and counting the flashes of the "check engine" light.
hi
its the exclamation icon near the oil and ECT/PWR light.
i had a puncture repaired a week before it started. usually if a light bulb burns it appears, so thats why i checked all my lights, but unfortunately its not a light bulb.
rick, can i self diagnose the car?
hi
It's either the brake fluid level or a brake light bulb......can't remember which. Did you check the centre brake light?
Indeed you can. Although your particular issue is one of the things as per Dave and Tony's replies.
yes, the strip brake light on the parcel shelf is working, i initially thought it was that, but its not. i will top up brake fluid and see
will update later
will update later
Did you cure the warning light?
