i hav8 the 8 speaker option on my 200 se, might change the head unit but wanna keep standard speakers, plus i can only account for 6 of the 8 speakers, main things are :-
how can i keep all 8 speakers when there are normaly only 4 outputs?
Who sells double din to single din adaptor plates???
Any good ideas for a stylish snd simple install?
cheers :withstupid:
do a search , theres loads of posts regarding this.....
there are 2 speakers under each rear speaker pod.
like i said do a search these very ideas have been considered before but theres more to it than just swapping the headunit
The Rear shelf speakers are actually 2 seperate speakers.
The mids and tweeters act together as 1 output, so that makes 2 outputs up front and correct me if i'm wrong but both the rears run on the same outputs too. So all in all that's 4 outputs. I think.
You can buy the replacement fascia at Autotoys.com.
As for installs you can buy a Stealth box at auto acoustics.
Alex
  • 9 months later...
Alex
Ah, you have the 'S', which only comes with a 6 speaker system. I think its no seperate tweeters at the front :question:
Anyway, has any used these stealth boxes with a boot liner?!?!
Still need to keep the car practical!!
