How Do You De Tango The Indicators On A Mk1?
There is a walk through on the forum somewhere. Try the search function. But it involves putting your headlights in the oven, taking them apart removong the orange filter the resealing them. I have done it with a set of old headlights but i got the common headlight fog problem. So i changed them to the dark spec ones.
here it is
http://www.clublexus.com/forums/gs-second-...er-removal.html
but i just dont wana take risk and i dont have spare set...any other safer option :)
No idea on the mk2 side of things, but on a UK mk1 GS, the front indicators are not part of the headlamp, only on imported aristos.
as title, i want to detango my indicators. how do u get the orange section out from inside the lense.
cheers. Anuj
Do you mean the front ones? If so, I de-tango'd my Mk1 front indicators and although awkward, it can be done without the need to put anything in the oven. Just use a screwdriver, side cutters and a pair of long nose pliers to break up the orange "cup" and pull it out of the bulb hole. I will be doing the rears at some point, just not got round to it yet so no idea if the lense needs taking off.
yeh front ones mate, i did look at it, did it take a while to get it out?
No, didn't take too long, it was awkward and just needed plenty of persistance and patience :P
