Cleaning Headlights
rite, i have a small problem thats starting to get on my nerves, if you look closely at the picture below you will see that the right headlight is dirty on the inside, is there any thing i can do like take the glass off and clean it or something like that.thanks.
Are you sure it's dirty on the inside and not on the outside ? It's usually the outside that can get discoloured, but you can use something like a clay bar or Brasso to fix that.
yeah its on the inside, ive tried compounding the outside just to see was it on the outside but no luck.
You'll have to take them apart then I'm afraid, like Asi said, by putting them in an oven. Use the search facility to find other threads on this, and feel free to ask more questions on how you do that if the other threads aren't quite clear.
thanks for that, and all the other replys im getting. at what heat would i put them on (very low heat?). i was also told to use a hairdryer or heat gun.
i put mine in the oven at 190 for 15 mins(fan assisted)BUT stay in the kitchen and watch them as it wont be the first time someone has melted their lights!!heat gun or hair dryer would take age's!!
how did you put the light back together, what did you use.
