Engine Bay Bolts?
Could anyone tell me the correct size/type/make of the hex bolts with flange i need for my is200 engine bay,a few of them are abit rusty and i'd like to replace them.
ive looked all round the forum to see if theres any infomation about this but was unable to find :(
im sorry if this has been asked before.
Thank you for your time.
M6 in various lengths :)
Which ones exactly, the engine cover bolts ? Or the ones at the front ? I've mentioned several so can give you some of the lengths if you want.
As Bazza says though, they're M6, so you can just take the ones out you want to replace and measure them, then order up suitable replacements off eBay.
I dug out some old threads, and the VVT-i cover takes 4 M6x25 bolts, with 13mm washer. The airbox cover takes 3 M6x30 bolts, with 21mm washer (poss need a second, smaller washer too).
The ones that go on near the radiator, e.g. to hold down a stainless radiator panel if you have one, are M6x12.
