Sc430 Rims On Ls400?
andyrh78
Hi again guys,
Can anyone confirm if the 18" alloys from an SC430 will fit a 1997 LS. I know they will on paper ie pcd etc, Im just concerned about the front calipers on my LS as they are the larger 4 pots.
Cheers.
they should mate but if they are a bit close you could do what stav done with his rx8 wheels on his lex(think hes using supra calipers)....a set of small wheel spacers will sort the problem out and you'll have the wheels you want on your car.
I'm pretty sure there's another member who has already done this as I'm sure I've seen an LS with SC wheels on it before (actually looked better than on the SC imo)
