Fitting Rear Arbs
Asi
hi there,
i still havent fitted my rear anti roll bar because prolex forgot to send me new bushes and it took almost 2-3 weeks for them to come so i just got my fornt ones fitted while the clutch was getting fitted. now i have the busses and anti roll bar. the question is how how is it to fit? isit a take off job and put on or it will require alot more?
thanks
There's a guide to fitting ARBs here, it doesn't look too hard. The only think that I think could be tricky is if your drop links are seized and therefore need cutting off. If your front ones are fine then hopefully the rear ones will be too.
If you've only got an uprated front ARB at the moment isn't the handling a bit weird ?
i didnt find it weird Stevie. still handles alot better than stock but lets see what difference the rear ones make. thanks for the link mate.
