Fault Code
hi
just changed my clutch got 1 off eBay £152 good deal thanks to you guys, still have a fault code p1126 which i think is magnetic clutch cct problem not been a machanic has any 1 any ideas how to sort my car out.
what is the magnetic clutch cct?
nice 1
johnjo
That's showing a problem in the magnetic clutch circuit on the throttle body. Nothing to do with your drivetrain clutch replacement.
I suspect that if you press the Snow mode button nothing will change when you're driving, because the car is working on manual throttle rather than electronic.
There's a guide on how to check it out here. In the worst case, you might be looking at a new throttle control motor.
Check there's nothing fouling the throttle cable that could be causing a problem.
thanks mate i will have a look at it
johnjo
