This Is The Code
For the throttle body, basically what happens is this. Instead of the accelerator pedal directly controlling how much the throttle opens and closes, this is controlled electronically. The accelerator pedal still have a cable going to the throttle body, but this doesn't operate the throttle directly, the input is read by the car's ECU and it then tells a motor on the throttle body how much to open/close the throttle.
Ok just trying to sort it out now.
Think I did some thing this morning to affect the working of it.
Have noticed what my mistake was.
Once i undo what I did and fix the thing I did, and take it for a test drive .
I will say what I think I did to make it not go right :nugget: :nugget:
But will only say if it works :lol: :lol:
Ok this is what happned.
I was going over my hose clips and I tightened up the small hose on the left beside the induction kit.
And the hose clip move round a bit and stopped the throttle cable from working, you know the one with the spring at the top.
So before I noticed that I checked inside the throttle body, I pulled the cable to see inside of it, it was then that I noticed the cable not being able to work at the other side.
I am so pleased now but also feal a bit daft. :blush: :blush: :blush:
