Another Part Fitted :-)
do the black do the black i've always had a soft spot for a red car with black detailing thinking the black chrome will look amazin!!!
ps how did you cut the sheet metal without rippling it?
The cover i've got on at the moment i cut out with an angle grinder, the last cover i made i cut out with a power saw?
All depends on what metal you use mate? mines 4mm alloy now and my old one was 1.6MM armour plate :whistling:
You could use something like 1mm polished stainless sheet which would be quite easy to cut and should still hold its shape, or go for a 1mm steel sheet and then spray it :)
