Hi
I can confirm everything Brian 26 has commented on. I have a 2010 rx450 and payed around £600 for the fitting and 13 pin electrics, the only issue was the fuse in the relay due to the electronic stability control on the Unicorn Vigo (1500cw)caravan , the fitters had to up grade the relay to the 20 amp fuse required. No cutting of the bumper, and when the removable tow hitch is removed the rear looks as it should.
Fitted my tow myself which was easy, apart from the electrics, one connection is above the roof lining and it's not easy identifying the correct wires as a lot of them are white so which one do you chose. When it came to running the 12v power to the rear I just put three wires, one for the fridge power and one for the permanent 12v and the other for the sense wire,  down a black plastic conduit and went from the Battery to the rear under the car and cable tied it on.
