Fuse Layouts
Is the extra lead you mention, which isn't connected, part of the amp bypass lead or part of the loom from the new head unit ? It might or might not be important.
The "Radio 2" fuse is used for a whole load of things as well as the stereo (electric windows, door locking, etc, etc), and is a switched live from the ignition. The "Radio 1" fuse is only used for the stereo and is a permanent live.
what do you mean by battery problems?
I mean Battery goes complete dead when car left overnight. Started since i changed stereo system thats why i am thinking its something to do with that or could be something else. Is it any point in changing to new Battery as Battery level shows 10v when jump started each time.
cheers
