Denso Spark Plugs And Oil Filter
DJ 2309
Oil filter from Lexus (with draining nut gasket) is about £9.50.
As for plugs, you could try US ebay- a lot of members have bought plugs from the US in the past- not sure if its cheaper now to buy from the US with the weak £.
Edit: Have you consider NGK plugs? They are the equivelant to the Denso's.
Do you know the part number I need for the NGK Plugs?
IFR6A11 for the NGK's, IK20's for the Denso's or SK20R11 for the longlife Denso's. The longlife ones last up 60k where as the IK20 Denso's are high performance plugs, but they last upto 30k.
