Wheel Size V Speed
wildrnes
Remember how much difference tread depth makes.
If you wheel is 30" overall diameter with 8mm of tread, then when the tyres are down to 2mm its only 29.5", thats a 2mph difference at the top end.
Tyre pressure can effect it even more than that, its easy for a wheels radius to be out by 5% cause of different tyre pressures (although less true on low profile tyres)
Chip
