Illuminated Scruf Plates
Bazza its very easy to make them any colour you like
if you look under the scuff plate it's just an oblong of EL light strip held in place with some selotape.
all you need to do is find a strip in the colour you like and solder 2 wires to the new strip
I have seen the electrolumenescent (spelling) strip on www.farnell.co.uk but im sure it can be had cheaper elsewhere. :alien:
Yes the Lexus ones come with an inverter that output 115 volts , you wont need another inverter unless you go for a different spec EL strip.
Your welcome :)
