I've been looking at the IO play adapter for Bluetooth handsfree and audio playback from my Iphone. seems like a decent bit of kit, I've tried to find a cable that will let me plug it into my GS300 mark 2 1999 with satnav. the best match I can find suggests a SOT 913 ISO converter cable which some websites say lexus upto 2005 and some say will not work with amplified systems.
Does anyone know if this lead or any other lead is the correct one for my car?
Many Thanks
I've been looking at the IO play adapter for bluetooth handsfree and audio playback from my iphone. seems like a decent bit of kit, I've tried to find a cable that will let me plug it into my GS300 mark 2 1999 with satnav. the best match I can find suggests a SOT 913 ISO converter cable which some websites say lexus upto 2005 and some say will not work with amplified systems.
Many Thanks
We ordered a SOT-913 and another lead (can't remember the number of that one) to fit a parrot to a 2004 GS300 with Mark Levinson. I will let you know if it works when they turn up!
Thanks for that :)
from what I can find out, theres a lead for GS 1993 - 1998 mk1 and another lead for 2000 - 2005 with a big gap in the middle where my car sits lol. Good luck with the lead
Many Thanks
Just be aware when fitting Parrot kits - They use "French" ISO connections (Crazy I know - but there is a French International Standard !!!)
Everything is correct apart from the Ign power and Continuous power - which are reversed.
Parrot kit will work - but you'll have no end of problems with it until you correct these. You know you have them the right way around if you get a "goodbye" on the screen (if you have a parrot kit with a screen)
Not just the french...a bunch of german carbrands do this aswell ;)
Our 913 lead eventually turned up although they've gave us the 913a instead of 913b which we ordered. The other lead is also wrong. This is what we got:
What i *think* we need is the 913b and maby the 06-429b:
Well we got the right cables which were the 913B and 426B:
The 913B easily plugged into the amp in the boot:
Some wires ran off to the front which connect to the 426B that plugged into the parrot:
The only problem that i had was the leads which they supplied were an old style one and a new style. The old style one has a 3.5mm jack connector and the new style had bullet connectors :blink: - this had me confused for quite a while! Chopped the jack off in the end and all works fine now :)
  • 1 year later...
Ok my dad sold the Lexus and we took the Parrot and wires out before selling, so i thought i would offer it for sale on here.
So what you would get is a Parrot 3200LS colour, with a Autoleads 913band 426b.
The Parrots go used on eBay for around £60-80 and the you can see from the link above that the cables are expensive.
So £100 for everything.
It doesn't have a bracket to hold the screen on as we didn't want to drill any holes. We used No more nails double sided sticky tape which worked fine. The mic has a tie which can be slid down the top of the pillar cover to keep secure.
The only thing it didn't do was mute the tweeters, but i have an email from Autoleads on how to correct this by switching a wire.
Thanks, James
  • 1 month later...
The Parrots go used on Ebay for around £60-80 and the you can see from the link above that the cables are expensive.
Thanks, James
This is now on the bay if anyone is interested:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem
