Head Lights
rach
can anyone suggest anything i have a Y reg IS200. i have just been told by a neighbour that my lights are on even though i had turned them off - they were on low and the fuse was making a vibrating rattly noise this has happened before and i replaced the fuse but now its happened again - the car is workig perfectly in all other ways. the only way i can turn off lights is to remove the fuse completely.
Has this happened to anyone else at all???
Have you had your windscreen replaced recently? I've heard about this on here before, and it often happens after the screen is not replaced properly, which allows water into the headlight relays.
Either way I think the fault is with the relays, but I'm sure someone else will be along shortly to confirm, welcome to LOC btw :)
