Turbo Timer Harness
jeffrosie
Though two other points,
1) technically they're illegal, same as remote start, as the cars running with no-one in it.
2) its not a simple matter of plug and play, because if you do the remote lock wont work, so you need to not connect the second ignition live, but then the alternator doesnt charge as the cars running so you drain the Battery a bit each time you use it.
see more here: http://my.is/forums/f114/turbo-timer-353349/#post5256836
Hope these help.
