Are all of the buttons on the dashboard and steering wheel illuminated at night/when the headlights are on? What about the electric window switched and the other buttons on the drivers door?
Also what is the reversing camera on the MM like at night?
Thanks for your time
Francis
everything on the centre console is lit and steering wheel on all models. on pre-08 models only the window switches i believe are lit, but on 08-present the wing mirror switches and fuel cap are lit too
The mm camera is generally fine at night. Just be aware of two things though;
- the little lens is not hidden and gets very grubby in the wet, esp in the winter and then you get a very blurred image!
- in the cold, the exhaust is very steamy on start up which can affect reversing visibility.
Thanks for the replies!
