Do You Need To Change
Hi i read some where if you change the timing belt you need to change the coolant.... What i WANT to know can it be done without changing the coolant... My car was in 8 months ago and i got it one by my local garage but I dont think he changed the coolant.... Thanks
i wouldnt of thought you'd have to change the coolant unless you have to take either the radiator off, or the pump and only then as it would of needed draining, i've not had to do this but it sounds logical enough
