Car Not Starting After Changing Leds In Dial
HiTnRuN
Hi guys,
I changed the LEDs in my dials when I put it all back together and tried to start it again, it just wouldn't start. It sounded like it usually does when it starts up, but it sounds like the cars not getting petrol and not starting? I drove the car twice earlier and when I tried to start the engine after changing the dials the engine was still slightly warm. I don't understand, could I have damaged something in the dial binacle which doesn't allow the car to start?
Thanks for your responces in advance, any help is much appreciated.
Sounds to me something is still disconnected or not plugged fully home ?
My dial has been out numerous times, and you do have to be quite firm to ensure the plugs are seated correctly.
So have you had the problem where your engine wont start when the connections are loose? I was sure I connected everything in correctly, used quite a bit of force and all the dials work, light up showing the mileage and the petrol amount? So surely the wires are connected properly? Or not?
As wozza says..
There is lead on the ignition barrel, i think its green, that is linked to the imobilizer..
sounds like thats disconnected...
another member, who i wont name, assured me he had connected this when we were working in his car and found he hadnt and had the same problem..
this was after trying evertyhing else to star the car!!
As wozza says..
who was that then :lol:
As wozza says..
That was it! I had forgot to plug the green wire back in lol. Thank god it was so minor, I was getting worried.
Thanks everyone for your help!
