Misfire
den_200
hi i have an is200 sc and on sunday i started it up and tryed to pull away and the rev's dieded off to idle. i worked out that if i only touch the throttle lightly it works ok so got it home like that. i have got spare coil packs and plugs at home so changed them but this has not helped at all. still ok till put throttle right down then it has a big misfire. any idea's :crybaby:
