Where Is The Pcv Valve On The 02' Gs 430
Hey guys, does any one know where the PCV valve is located on the 2001-2005 GS 430, I'd like to change mine.
Try the inlet manifold. Have you a specific reason to change it? If you are having problems with it a good clean is usually sufficient.
Na, no problems, no reason...I'm just used to changing it in my american car. Now I'm vexed that I can't locate it. Thanks for the link Mark.
PCV Valve found! The PCV valve is to the left of the oil fill location ON the valve cover... drivers side, in about the 8 o'clock position from the oil fill location (looking from the front of the vehicle). It's covered by a foam protector so it's a little hard to spot. The hose coming from it is also protected with a foam type cover (an 1" + 1/4 radius). It comes from the top/front of the engine just above the large intake air hose.
