I am trying to do a Diagnostic Check on my 91 LS. I have bridged a wire between TE1 & E1 in the port under the steering wheel, put the car in neutral and made sure air con is off but the engine light just continues to flash constantly with no breaks to determine a code number. What am I doing wrong? Any advise would be greatly appreciated.
does it flash when driving ?
I presume you are reading it without the engine running
