Ls400 V8 Into My Is200
MeMo
sounds a bit rough lol
good to see it running though.
no stop messing about loading vids and get back on with it :lol:
yea its going to sound rough mate, but i have to say it sounds alot better when you are standing next to it :winky: as soon as i get the turbo fitted next week and the down pipe on i will put a new vid up of it .
Awesome mate. Well done B)
Mind you, that altenator looks less than stable on that bracket :unsure:
Thanks mate, yea the ATL has 4 blots holding it but they are not done up as it has to come back of , and thats why it dont look stable :whistling:
As already said it does sound like it's only firing a couple of cylinders but i assume that is down to the fact it only has a manifold on and the sound probably isn't that good on the vid.
Nevertheless it is always a good day when you start and engine for the first time. Looking forward to seeing/hearing it with the tubbie mate.
Well Thanks to Ellz B) i have a nice set of DBA, GOLD,s front & back for the IS, and by the looks of them they are not that old, just need to repaint the gold bits, and they will look good as new :) Thanks mate :winky:
i will fit them over the weekend, i should also have the turbo Down pipe all connected up to the exhaust, and turbo oil lines connected up, i will then take a new vid of the car, and it should sound alot better :whistling:
UPDATE!!!
Hi guys,
I got some more done on the car, last week i took my turbo Houseing to a Hotrod place i know, took it there as i have seen there work and its very good, i needed a pipe welded to the outlet so when i come to connect the hose to the it it will not hit the manifold, well i went and pick that up to day, and very nice job the guy did, I also got the pipe work for the rad done and thay are all connected up now, took the down/pipe of so i could weld 2 O2 sensor Nuts on it, thats all done and put back on the car, now i have the intercooler pipe work to line up and mark, then i can take it of to get welded.....
UPDATE!!!
Hi guys,
Nice mate :D
Going to need some serious tread on the rear end mate to hold that down? :o :lol:
HHmm yea i know, but the wheels i have on the car now! i can only go to a max of 255 i think,
well i got the DBA discs, on the car today, and took the back brake,s of so i could give them a nice repaint, well most of the wrok is done as you can see by the pic,s
see the custom rad pipes i had to make, + the ALT mount (just about see it) & the air sensor
Nice HKS Air fillter, and wastegate (just about see the wastegate) B)
The brakes i repainted
DBA, discs i got from Ellz, i repainted them GOLD as they are the DBA golds come up very nice.
still waiting for the pipe to come so i can connect the Exhaust up to the down pipe on turbo. Intercooler pipe work is of to the welders over the weekend.
