Ls400 V8 Into My Is200
MeMo
Hi all
I started my Conversion on my IS200 some months ago to put the 4L V8 1UZ-FE thats in the Lexus LS400
The Engine has done 120,000 miles but then so has my IS200, so i dont only have the engine i have the rest of the car as well to get some bits off. as its been done before........i have get all the info i need, the gearbox is going to take most of the time to do as the LS gearbox is auto and i want to convert it to manual...........i know there are 2 or 3 gearboxs out there that will fit but i will have to swap the bellhousing over for a custom made one, that i will be geting from ThorRacing
as for the ECU.........I will be useing the LinksPlus standalone....ECU
as for fueling, i will be keeping the std njectors for now. i have all so run new lines from the tank to FPR to fuel rails & return lines
dont think i will have to mod the sump like on most Conversion,s on the IS as the sump on the 1UZ-FE sits at the front of the engine so it should fit over the cross member on the IS,
the good thing about this swap is that the 1UZ is an all aluminum construction that makes it just as light as the 1G-FE + The Rods are factory forged units, + it has factory forged crank as well.
I will be useing the (R154) 5 speed Supra box, once the car is up and running that is, to start with im useing the auto/box from the LS400
..............some more info to come & pic,s as well :)
Hear is the V8 in my workshop, had to do some work to it...
http://links.pictures.aol.com/pic/d610zsDH...w*IV**GT5_l.jpg
http://links.pictures.aol.com/pic/d610zsDH...aao9bblGX_l.jpg
http://links.pictures.aol.com/pic/d610zsDH...mqgmB-Z5v_l.jpg
http://links.pictures.aol.com/pic/d610zsDH...Zgj0LRlzh_l.jpg
http://links.pictures.aol.com/pic/d610zsDH...ixrYS2GK6_l.jpg
and hear i am test fiting the V8 in the IS :)
http://links.pictures.aol.com/pic/d610zsDH...-*L5ugiCO_l.jpg
http://links.pictures.aol.com/pic/d610zsDH...WkiDSkozx_l.jpg
http://links.pictures.aol.com/pic/d610zsDH...SVC8VZYu1_l.jpg
and this is when i frist droped the V8 in the IS
http://links.pictures.aol.com/pic/d610zsDH...P0R0dRyHR_l.jpg
http://links.pictures.aol.com/pic/d610zsDH...pz2keJgtX_l.jpg
and at that point, there was still lots of work to be done, as the V8 was just siting there. i had to then see what room i had for the manifolds & all so see what room i had for the Turbo, Rad, and all the intercooler pipe work,
and as you can see by this pic, i had my hands full lol :D
http://links.pictures.aol.com/pic/d610zsDH...*oRChyKHY_l.jpg
some pic,s of what the car looks like now.....
http://links.pictures.aol.com/pic/d610zsDH...fInu3T8p-_l.jpg
http://links.pictures.aol.com/pic/d610zsDH...1lV7JRT3Q_l.jpg
http://links.pictures.aol.com/pic/d610zsDH...iiVrYwc*c_l.jpg
http://links.pictures.aol.com/pic/d610zsDH...gd4wNHaVa_l.jpg
more pic,s of some parts that i will be useing.....
http://links.pictures.aol.com/pic/d610zsDH...oxU2o7x56_l.jpg
http://links.pictures.aol.com/pic/d610zsDH...By7abpBKG_l.jpg
http://links.pictures.aol.com/pic/d610zsDH...7alLGscSv_l.jpg
The R154 gearbox..
http://links.pictures.aol.com/pic/d610zsDH...bQ61AzGOn_l.jpg
http://links.pictures.aol.com/pic/d610zsDH...W4zGt-FTB_l.jpg
use a free photobucket account to host the pics Marcus :)
i will do when i get time mate, as all the pic,s are on AOL and i will have to put them all on photobucket and that will take some time :(
