Cloudy Yellow Headlights...
Sang
Does anyone have any remedies for the front head light unit? The plastic seems to have gone dull with age is there anything i can use to clear it back up so that it looks as good as new?
What's Brasso? is that the brand or the product name?
Yes mate, Brasso is a brand of metal cleaner that can be brought at most shops like Asda, tesco etc, But its only a mild cleaner/polish that will remove dirt from the laquer on the light lenses, I used to build headlamps and we used it all the time to remove scratches and marks from the lenses and does work quite well,
T-cut does the same thing as again its only a light abrasive and should remove the discolouring from the headlamps and can be brought from most car shops :)
If Brasso does n't work, try wet sanding with 800 - 1200 - 2000 grid sandpaper (maybe the 800 can be skipped if your headlights is not so bad) and then a good rub with some paint finishing compound (i used 3M in a black bottle).
That method worked miracles to me!
  • 4 years later...
You could also toothpaste, it actually works,
Its only a short term fix toothpaste, best wet n dry and polishing with cutting compound, done a few sets now and thats the best i find!
I tried using a clay car and some detailing spray on mine as they look a bit aged. It made an improvement , bun not what I was hoping for.
http://www.lexusownersclub.co.uk/forum/topic/82955-my-is200-respray-done/page-4
I should give Brasso a shot. Will pick up some tomorrow.
Edited by HoodRich
