New Is200 S Owner :d
Garysean
Hey guys just took ownership of a nice 02 plate IS200 :D, it's only done 40,000 miles but i believe it's timeing belt change time (6 years or 60,000 miles ?) anyone know what the rough price for that is ? also anyone any suggestions what essential work/checks i should get done i've heard alot about WIM recently by looking at new memebers posts can anyone explain what this is ?
Thanks guys
WIM are great. Very highly recommended. You do hear that a lot, but if you do not know what "WIM" is then I guess it makes no sense!
WIM is Wheels in Motion, www.wheels-inmotion.co.uk, run by Tony, who is also a member on here. Basically they are suspension specialists. There is a well know common fault on the IS200 of the suspension geometry being wrong. This causes excessive wear on the tyres, particularly the inside of the fronts, and worse if you drive hard. The settings issued by Lexus are wrong, so if the geometry has been set by someone else since, there's still at least a 90% change it is still wrong.
Tony@WIM has developed optimum settings and has correctly literally hundreds of IS200 in the last few years, and I'd probably be right in saying they are all more than happy! Cost around £100, I think, and will improve tyre life and general handling and road holding.
If you don't know if your car has been "WIM'd" then you should get it done, IMO!
No idea cost of cam belt, but someone who does will be along soon, I can guarantee it!
EDIT: Checking your location, it would be quite a trek to WIM for you. Tony is a nice guy, and will supply the settings so as you can get it done more locally, maybe even recommend somewhere.
Welcome to LOC mate, i'm from Greenock and found a guy in Hillington that does the geomtry set-up. I got the settings from Tony @ WIM and took them to the guy last week and he was happy to set it @ Tony's settings. This guy specialises in this kind of stuff and charged me £141, he said mines was quite abit out, ie maybe skelped a kerb or two at some point. Iv'e to take the car back next week and he'll check over it to make sure it has settled ok, The bloke was sound.
Tommy
Or maybe they have just always been that far out! (Would not have ever been at Tony's settings before!)
Welcome to LOC, I've got an '02' as well and just had my cambelt done at Lexus, cost £695.....
That is steep. Can be done for half that, I'd have thought (though admittedly probably not by Lexus.)
Hey guys thanks for the welcome got to say what a car lol can't get enough of it :P.
I'll pm Tony thanks for the heads up :D...Tommy where abouts in Hillington m8 as it's something i want to get done asap along with a cambelt change...although £695 seems exspensive i'll try and find a specilist see if there any cheaper a friend told me he knows someone for £200 so need to see if thats true as i don't fancy the DIY option lol.
Hi Garysean, he's called Kenneth Brown Motors, Unit 7 Block 108,36, Hepburn Rd, Hillington Industrial Estate, Glasgow, Lanarkshire G52 4RT, Tel- 0141 952 4499, he will also give you a price on cam belt change, seemed to know his stuff on IS 200's.
Good Luck
Tommy
