Power Out Put Of The Standard Engine V Supercharged
ibby
Hello
I am looking for a STOCK power versus the TTE Supercharged engine.
I know what the increases are, but I am more intrested in where the increases are felt.
Ie lower down the rev range.
If any one has any DYNOS - Would apreciate it
Thanks.
Interesting graphs there, not sure how I missed that thread in the first place...........
What was going on with the autos though? What exactly happens during a dyno that would be a problem for autos? (got to admit I don't really know what happens other than what I've seen on youtube videos of cars having their engines revved on the machine..............)
They work out the Flywheel horsepower by measuring the drag on the gearbox/drivetrain from peak revs down to idle after the
RWHP is measured, for this the vehicle has to stay in the same gear to measure the drag (an auto will change down), then the
info is calculated to get the flywheel figure.
Apologies if that isn't worded correctly, as I'm no mechanic/dyno operator, but that's my understanding how it works,
and why I have been LED to believe you can't get an accurate dyno result. If it's bs it is plausible bs IMO.
Standard IS200 is supposed to be 153bhp @ the fly, TTE Supercharged IS200 204bhp @ the fly.
Hello
Thanks.
The increases are felt across the hole rev range, as your/the supercharger works of belt drive from you engine, the more you rev, the faster it will spin, so from the off you have the power :D
