Im A Newbie, Would This Rims Fit With A Little Work Done?
nissansilvia
I am running 8J ET45 225/40/18 on the front, and they only just miss the front upper control arm.
I am running 8.5J ET50 255/40/18 on the rear and had to have the arches cut slightly.
This is on a non lowered SE model that sits higher than the Sport.
I think the fronts won't fit because of the control arm, and the rears would need the arches pulling out quite a bit
(or even arch extentions of some sort) as the wheel will stick out past the arch.
Also if you check picture number 6 when you supersize, that wheel needs a new tyre :o
