Couple Of Questions
muddyell
Right then guys i have seen a VVTi controller and just wondered if it would be worth buyin? Do any of you have them on your car?
Also where can i get all the TRD or TTE lips from because i had a little bit of heavy right foot syndrome not so long back and the back end of the car came out :whistling: well i kind of hit some gravel which screwed me right up and i hit a post :crybaby:
The damage aint too bad so will take it into the bodyshop to be repaired but no point in puttin it back standard lol may aswell put the lip on while i am at it, and maybe put the rest of them on too :winky:
Oh yea i need a new washer bottle too :blush:
Thanks guys
vvti controler ? can they be used on the Is200 ??
i thought they was only conpatiable with Type R's ?
i'd be defo getting one if they work.
There is two types of CAMCON,
The honda type (Vtec Yo!) and the Toyota VVTi type.
They do ,ake some difference and if you use the search button at the top theres a feqw threads on it.
You will get a few BHP maybe, 3-4? but its up to you to weigh gain vs cost.
