H.i.d Install
karlp606
Sorry guys I know its another HID topic.
Just got mine delivered today from eBay all looks good but as anyone provided a walkthrough where to install ballast etc and with pics.
Would be a great help cheers
Also should you drill your ballasts on or just tie wrap?
Cheers
There is a fair bit of room near the suspension turrets if your leads will reach that far. There is loads of space on the driver's side, mine is mounted near the headlight on that side, on the roughly-horizontally-flat bit of the engine bay. On the passenger side it's a bit more cramped, mine is on the side of the suspension turret there.
I will take and post pictures of my installation in the morning, if someone hasn't already beaten me to it.
As has been said, sticky foam pads are great for the job.
A member on here Tony Goose fitted his under the drivers side headlight and the other one under the windscreen washer bottle no need to drill just use double sided tape
Close :) Under both headlights bonded not drilled.
On left side there's just enough room for the ballast to sit between top of washer bottle and underside of headlamp.
Right side there's a cavern like space under the light so plenty of room.
TG
Hi karlp
I have this mod and totally recommend it.
I have attached a link to my installation pics to show where I mounted the ballast's - on the suspension turrets.
HERE
Edited by DJ Wozza
Sorted link
