Advice Needed
brianon
I have an ES 300, 1992 with a 5 speed manual. I am wondering how I can replace the gearbox lube. Does anyone know where the fluid drain is located on the gearbox and where the fresh lube goes? I just replaced the hydraulic master clutch so I am aware of that procedure and the brake fluid it takes, but what about the procedure ffor the gearbox?
Bri
