Is300 - Cel, Vsc, And Trac Off Lights Are On
JKarpala
It happened again...the Check Engine Light, VSC, and TRAC OFF lights are on but car runs just fine. First time it was gas cap not properly tightened-up. Took to dealer and they cleared the codes - all is OK, no cost car on warranty.
I want to clear the codes by myself this time because the vehical is out off warranty and I tried it yestarday - turned the car off, pulled EFI fuse out for at least a 1/2 hr and even pumped a break pedal 20 times - nothing - the lights are still on.
I thought to check with you guys before I pull the negative on the Battery...
Your help is greately apreciated.
Thanks,
Jacek
I thought to check with you guys before I pull the negative on the battery...
Thanks,
Jacek
You have to pull 2 fuse mate, not sure if thay are the same on the is300 ? other than that pull the Battery for 1/2 hr :D
If the fault is gone then the lights should go out after three ignition off > start engine > run for 20 seconds > ignition off cycles.
If the light doesn't go out after that then there is still a fault. Those lights can come on for a number of different reasons, not just the fuel cap.
  • 2 months later...
Not sure if it is the same problem i had today but I checked all my connections in the engine bay. Turned out a few were loose cause of engine vibrations and such. Remember that if it is a "soft code" (non-terminal) the lights will go out when the problem is fixed. If that doesn't work try taking to any Toyata experienced aftermarket shop, a shop dealing in Supras will usually be able to help.
