Snapped Wheel Bolt
Rabster
OK so im stupid
i was putting my wheels back on after painting the calipers and this wheel nut was just not tightening up then all of sudden it fell off lol
how hard is it to fix may be a stupid question but better safe than sorry
easy get the old end out of the hub hit it with a hammer and screw driver then
once u got the new one push in from back and using a open ended nut tighten without wheel on till
the back is flush how it should be like the others
done it loads of times mi self on various models
any problems or if u live near call in to pemberton tyres in wigan
will i need to remove any other bits and pieces to do that or will it just push through and out the back things like disc and calipers wont be in the way will they ?
cheers
yeah its all wozzas fault lol
but on a plus side i have removed the remails of the stud
down side lexus dont carry them in stock how stupid is that
can some one tell me what do they actually carry in stock other that lexus merchandise and a coffee machine in reception lol
yeah just the wheel stud
still dont know how i did it lol it didnt cross thread etc
I found whenever I had a fuzzy looking wheel bolt it would break. Take another pic of the rest of them, if they are as fuzzy as this one, I would get a whole new set :whistling:
Does look a bit thinner and stretched mind you. Just over tightened by the looks of it. When you torque them up to the proper amount, it is remarkable how little effort it takes for the correct amount.
