Is 300 Exhaust Advice
I stand to be corrected, but I am pretty sure the IS200/IS300 share an exhaust system from behind the main cat ?
Blueflame & Janspeed sound pretty good, and seem good value too on N/A & S/C IS200's and would suggest
the same for the IS300.
Others will (I am sure) correct me if I am wrong.
Not sure, but I think the shiny pipey bit that sticks out at the back is larger than the shiney pipey bit that was on my 200 ? (!)
I think that Janet is right - longer too maybe.
Keep us informed as to how you get on as I'll be in the market for a back box (and pipe) pretty soon...
Good luck
Jack
The back box on the is300 is the same fitment as the is200/Altezza :D Eg, one back box will fit all 3 models :D
Good luck
Jack
Second that Gord, the one I have on the Tezza came off Fargo's 300.
The tail pipe probably will be bigger on the 300 than 200. But the fitment will be the same, which gives you the same choice of aftermarket can.
HKS do a couple of beauties, depending on what kinda volume ure looking for. Veilside do a nice one too.
