Indicator Question
Golgarth
If the stock indicators are amber coloured bulbs, then they will be offset pins. The only time they should be straight is if like with my BMW where I changed the whole indicators from orange to clears, and an amber/silvertec bulb had to replace a standard clear bulb (which shines through orange plastic). In those cases, you need straight pins. Basically, if you have amber bulbs from the factory, you need offset, if you have clear bulbs from the factory, you need straight. All assuming they are
