Denso Plugs
Have you connected everything up? Nothing is unplugged? This is what I would check 1st. If all is ok, then reset the ECU (by disconnecting the Battery or pulling out the fuses, can't remember which ones now). If all is well, the CEL should go out, if not, then something else is causing the problem.
Have you connected everything up? Nothing is unplugged? This is what I would check 1st. If all is ok, then reset the ECU (by disconnecting the battery or pulling out the fuses, can't remember which ones now). If all is well, the CEL should go out, if not, then something else is causing the problem.
Yeah checked all plugs wires etc, will reset ecu tomorrow and hopefully all will be well thanks
  • 1 month later...
