Some Weight In The Boot Helps Rwd Car's Handling?
More grip at the rear doesn't always mean better handling as you can make the rear end too heavy and lose balance..........
I did recently realise there is a difference though when I drove around for a bit with no spare wheel in the boot, and it was only after a few hairy moments I promptly decided to put it back!
too much weight will affect your mpg...and will put extra stress on your suspension. Also may lead to faster tyre wear.
